does anyone know of any tutorials for building reports in ignition 8. I cant seem to even bind a tag value to a graph in a report and the inductive university video dont give a great explanation on how to graph tag values. Im new to ignition design and any pointers would help.
If your trying to graph it then you would need values over time. Have you set up historian for the tag or any sql logging? If you have done either then you would pull it back in using the tag history query or an SQL query. After you have the data being queried then the manual explains how to set up the chart under “Getting Started With Report Charts”
This was very helpful. Thank You!
