I recently upgraded my laptop and every since the upgrade, I get a Address already in use error while using the designer. I've looked in the forum and i found a bunch of posts about it but i can't figure out why this is happening. It happens so often that it makes it really frustrating to use the designer to do anything.
Error log attached.
13:09:55.320 [DesignerExecEngine-4] INFO tags.subscriptions - Changing connected quality to 'Bad_Stale'
13:09:55.320 [DesignerExecEngine-4] INFO Scripting.ScriptManager.L1Scada - Pausing scripts...
13:09:55.320 [DesignerExecEngine-4] INFO com.inductiveautomation.ignition.client.gateway_interface.GatewayConnectionManager - Starting reconnect thread.
13:09:55.339 [AWT-EventQueue-0] WARN com.inductiveautomation.ignition.client.gateway_interface.GatewayConnectionManager - Connection to Gateway lost, due to exception.
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Address already in use: connect
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:360)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:556)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:292)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:287)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:967)
at com.inductiveautomation.ignition.client.tags.impl.ClientTagManagerImpl.getProviderProperties(ClientTagManagerImpl.java:328)
at com.inductiveautomation.ignition.designer.tags.frame.TagBrowserFrame$getProviders$1.invokeSuspend(TagBrowserFrame.kt:133)
at kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(ContinuationImpl.kt:33)
at kotlinx.coroutines.DispatchedTask.run(DispatchedTask.kt:106)
Caused by: java.net.BindException: Address already in use: connect
at java.base/java.net.PlainSocketImpl.waitForConnect(Native Method)
at java.base/java.net.PlainSocketImpl.socketConnect(Unknown Source)
at java.base/java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
at java.base/java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
at java.base/java.net.AbstractPlainSocketImpl.connect(Unknown Source)
at java.base/java.net.Socket.connect(Unknown Source)
at java.base/sun.net.NetworkClient.doConnect(Unknown Source)
at java.base/sun.net.www.http.HttpClient.openServer(Unknown Source)
at java.base/sun.net.www.http.HttpClient.<init>(Unknown Source)
at java.base/sun.net.www.http.HttpClient.New(Unknown Source)
at java.base/sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(Unknown Source)
at java.base/sun.net.www.protocol.http.HttpURLConnection.plainConnect0(Unknown Source)
at java.base/sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
at java.base/sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source)
at java.base/sun.net.www.protocol.http.HttpURLConnection.getOutputStream0(Unknown Source)
at java.base/sun.net.www.protocol.http.HttpURLConnection.getOutputStream(Unknown Source)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:423)
... 20 common frames omitted
13:09:55.348 [AWT-EventQueue-0] INFO tags.subscriptions - Changing connected quality to 'Bad_Stale'
13:09:55.348 [AWT-EventQueue-0] INFO Scripting.ScriptManager.L1Scada - Pausing scripts...
13:09:55.349 [AWT-EventQueue-0] INFO com.inductiveautomation.ignition.client.gateway_interface.GatewayConnectionManager - Starting reconnect thread.
13:09:55.349 [AWT-EventQueue-0] ERROR tags.manager - Error retrieving tag providers.
13:09:55.334 [GatewayConnection-1] INFO tags.subscriptions - Changing connected quality to 'Good'
13:09:55.334 [GatewayConnection-1] INFO Scripting.ScriptManager.L1Scada - Resuming scripts...
13:09:55.340 [GatewayConnection-1] INFO com.inductiveautomation.ignition.client.gateway_interface.GatewayConnectionManager - Stopping reconnect thread.
13:09:55.362 [GatewayConnection-1] INFO tags.subscriptions - Changing connected quality to 'Good'
13:09:55.362 [GatewayConnection-1] INFO Scripting.ScriptManager.L1Scada - Resuming scripts...
13:09:55.363 [DesignerExecEngine-2] WARN com.inductiveautomation.ignition.client.gateway_interface.GatewayConnectionManager - Connection to Gateway lost, due to exception.
at com.inductiveautomation.ignition.client.tags.impl.ClientTagSubscriptionManager.syncSubscriptions(ClientTagSubscriptionManager.java:324)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:587)
at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source)
... 11 common frames omitted
13:09:55.365 [GatewayConnection-1] INFO com.inductiveautomation.ignition.client.gateway_interface.GatewayConnectionManager - Stopping reconnect thread.
13:09:55.378 [DesignerExecEngine-2] INFO tags.subscriptions - Changing connected quality to 'Bad_Stale'
13:09:55.378 [DesignerExecEngine-2] INFO Scripting.ScriptManager.L1Scada - Pausing scripts...
13:09:55.378 [DesignerExecEngine-2] INFO com.inductiveautomation.ignition.client.gateway_interface.GatewayConnectionManager - Starting reconnect thread.
13:09:55.378 [DesignerExecEngine-2] ERROR tags.subscriptions - Error updating tag subscriptions on gateway.
13:09:55.378 [DesignerExecEngine-2] WARN tags.subscriptions - Subscription crc mismatch, will resubscribe.
13:09:55.387 [GatewayConnection-1] INFO tags.subscriptions - Changing connected quality to 'Good'
13:09:55.387 [GatewayConnection-1] INFO Scripting.ScriptManager.L1Scada - Resuming scripts...
13:09:55.391 [GatewayConnection-1] INFO com.inductiveautomation.ignition.client.gateway_interface.GatewayConnectionManager - Stopping reconnect thread.
