I deleted the “admin” user while logged on as such. I had another user with “developer” privileges that now does not seem work either and I cannot log in either the “Developer” nor the gateway through the web interface.
Is there a way of restoring the original users without losing the project?
Carlos
From the Gateway Control Utility you should be able to issue a reset password command. If that doesn’t work let us know, there’s still an alternate if that fails.
That did the trick.
Thanks for the prompt reply
