Advanced SQL Query Help
Hello people,
I want to achieve something like below snip:
How can I do it through SQL? I am using MSSQL.
Note that Col4 is also there for ID1 but since - (empty) value in Table 2, I have skipped it from Expected table.
I need generated result as a Dataset
Where are you actually pulling this info from?
I will be pulling it from MSSQL.
And you want to put it into tables on perspective?
Or are you just creating a new table in MSSQL?
Ah yes, I want the output as dataset. that could be placed in Table in Perspective
Is there anything in table 2 to preserve row order?
Yes there is a column called StepName. I have updated snip in the post
Might be able to use a pivot?
How..?
Stack overflow :slight_smile: I don't use pivots enough to offer quick help at the moment sorry
Use SQL, returning JSON, to build Table 1 and Table 2:
Table 1 data will be something like:
   {'id': 1, 'col1': 'AAA', 'col2':BBB},
   {'id': 2, 'col1': 'FFF', 'col2':GGG}
Table 2 will be something like:
   {'id': 1, 'col1': 111, 'col2': 222, 'StepName':1},
   {'id': 1, 'col1': 444, 'col2': None, 'StepName':2},
   {'id': 1, 'col1': None, 'col2': 888, 'StepName':3},
Then organize the data with a script like:
table_1 = [
   {'id': 1, 'col1': 'AAA', 'col2':'BBB'},
   {'id': 2, 'col1': 'FFF', 'col2':'GGG'}
table_2 = [
result_value = []
for item in table_1:
	if item['id'] == 1:
		col_dict = item
		del col_dict['id']
		break
for item in table_2:
	if item['id'] == 1:
		result_value.append({col_dict_val: item[col_dict_key] for col_dict_key, col_dict_val in col_dict.items()})
		result_value[-1]['StepName'] = item['StepName']
print result_value
