AES 256 Encryption Using Scripting?
I need to encrypt a string using AES 256. Is there a way to do it within Ignition?
I found 128 bit Encryption code and it's working fine. could any body Suggest me what the code modification need to be done for get 256bit Encryption ???.
#AES 128 Bit Script
from java.util import Base64
from javax.crypto import Cipher
from javax.crypto.spec import IvParameterSpec
from javax.crypto.spec import SecretKeySpec
import java.lang.Exception
logger = system.util.getLogger(‘encryptionLogger’)
_encryptionKey = ‘ABCDEFGHIJKLMNOP’
_characterEncoding = ‘UTF-8’
_cipherTransformation = ‘AES/CBC/PKCS5PADDING’
_aesEncryptionAlgorithem = ‘AES’
def encrypt(plainText):
encryptedText = ‘’
try:
cipher = Cipher.getInstance(_cipherTransformation)
key = _encryptionKey.encode(‘utf-8’)
secretKey = SecretKeySpec(key,‘AES’)
ivParameterSpec = IvParameterSpec(key)
cipher.init(Cipher.ENCRYPT_MODE,secretKey,ivParameterSpec)
cipherText = cipher.doFinal(plainText.encode(‘UTF-8’))
encoder = Base64.getEncoder()
encryptedText = encoder.encodeToString(cipherText)
except Exception, e:
logger.warnf(‘Encrypt Exception: %s’,e)
return encryptedText
def decrypt(encryptedText):
decryptedText = ‘’
try:
	key = _encryptionKey.encode('utf-8')
	secretKey = SecretKeySpec(key,'AES')
	cipher.init(Cipher.DECRYPT_MODE,secretKey,ivParameterSpec)
	decoder = Base64.getDecoder()
	cipherText = decoder.decode(encryptedText.encode('UTF-8'))
	decryptedText = ''.join(map(chr,cipher.doFinal(cipherText)))
	logger.warnf('Decrypt Exception: %s',e)
return decryptedText
I adapted this AES 256 encryption Java example straight from this link You should be able to adapt the decryption part from my example below.
Working code
from javax.crypto       import SecretKey
from javax.crypto       import SecretKeyFactory
from javax.crypto.spec  import PBEKeySpec
from java.nio.charset   import StandardCharsets
from java.security.spec import KeySpec
logger = system.util.getLogger('encryptionLogger')
SECRET_KEY = 'one_key_to_rule_them_all'
SALT = 'salt_of_the_earth'
def encrypt(strToEncrypt):
	encryptedText = ''
	try:
		iv = [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
		ivspec = IvParameterSpec(iv)
		factory = SecretKeyFactory.getInstance("PBKDF2WithHmacSHA256")
		spec = PBEKeySpec(list(SECRET_KEY), SALT.encode("UTF-8"), 65536, 256)
		tmp = factory.generateSecret(spec)
		secretKey = SecretKeySpec(tmp.getEncoded(), "AES")
		cipher = Cipher.getInstance("AES/CBC/PKCS5Padding");
		cipher.init(Cipher.ENCRYPT_MODE, secretKey, ivspec);
		cipherText = cipher.doFinal(strToEncrypt.encode("UTF-8"))
		logger.warnf("Encrypt Exception: %s",e)
print encrypt("foo")
Thank you so much
