Just a note on setting up an Airlink Raven XE on AT&T’s network. If you find that the modem is not connecting to the network you might have to set the APN (Access Point Name) in the modem. It is located under the WAN/Cellular in the section. In my case I had to set it to ‘broadband’, without quotes.
