I have an existing alarm pipeline that I am adding alarms to call out on. The message is
At {eventTime|hh:mm:ss}, alarm "{name}" at "{displayPath}" transitioned to {eventState}.
However, my new alarms use the label and display path properties instead of the name and display path properties. So, the new alarms also have the custom message property set at the alarm configuration level on the tag:
At {eventTime|hh:mm:ss}, alarm "{label}" at "{displayPath}" transitioned to {eventState}.
However, the alarms that I'm seeing still use the message that is configured within the pipeline. Should it not be using the custom message?
If the existing alarms had the active event before you made the change, they won't be changed. They have to be inactive first and the next time they become active, they should have the change.
