Alarm History does not appear
If you look at the screen, I put true in History Enabled, but why doesn't it appear in "Attachment 2"?
Please tell me the solution.
Were those alarms active in the last 8 hours? That's what your filter is currently set to. Can you also share a screenshot of your database connections?
Edit: And Alarm Journal*
The 'History Enabled' you've turned to true is not for alarm history, that is tag history. You should make sure you have an alarm journal setup in the gateway(Config>Alarming>Journal). Then in Perpsective you'll need to make sure you alarm journal's name property is exactly as defined in the gateway.
