Hello,
One of my clients actually have some problems with his Alarm Journal. It appears that events coming to the journal are quarantined. I haven’t found any place to find out what alarm(s) is concerned and why the storage to database fails.
The buffer is filling and fills again as soon as the quarantined data are “retried”.
From his logs, I’ve found several succession of lines likes these ones:
INFO   | jvm 2    | 2015/10/21 15:26:02 | TRACE [Journal[ALARMES_HISTO]        ] [15:26:02,174]: Sending log event for UUID 'd04e17f6-8676-4ab4-8d5a-08feb792884c' to store and forward system.
INFO   | jvm 2    | 2015/10/21 15:26:02 | TRACE [Journal[ALARMES_HISTO]        ] [15:26:02,379]: Will not store event data for property 'setpointA': either the property is not the correct type, or the event type is not configured for storage. [setpointA]
INFO   | jvm 2    | 2015/10/21 15:26:02 | TRACE [Journal[ALARMES_HISTO]        ] [15:26:02,379]: Will not store event data for property 'eventValue': either the property is not the correct type, or the event type is not configured for storage. [eventValue]
INFO   | jvm 2    | 2015/10/21 15:26:02 | TRACE [Journal[ALARMES_HISTO]        ] [15:26:02,379]: Will not store event data for property 'activePipeline': either the property is not the correct type, or the event type is not configured for storage. [activePipeline]
INFO   | jvm 2    | 2015/10/21 15:26:02 | TRACE [Journal[ALARMES_HISTO]        ] [15:26:02,379]: Will not store event data for property 'name': either the property is not the correct type, or the event type is not configured for storage. [name]
INFO   | jvm 2    | 2015/10/21 15:26:02 | TRACE [Journal[ALARMES_HISTO]        ] [15:26:02,379]: Will not store event data for property 'eventTime': either the property is not the correct type, or the event type is not configured for storage. [eventTime]
INFO   | jvm 2    | 2015/10/21 15:26:02 | TRACE [Journal[ALARMES_HISTO]        ] [15:26:02,381]: Stored event to alarm journal (prov:ADM:/tag:TAGS ADM/MOULIN/DEFAUT_W_4/S2_HAUT:/alm:NIVEAU HAUT ATTEINT DANS LA CHAMBRE 2, , d04e17f6-8676-4ab4-8d5a-08feb792884c, 0, 0, [{Mode=0, setpointA=1.0, eventValue=true, activePipeline=0.0, TimeOnDelaySeconds=0.0, name=NIVEAU HAUT ATTEINT DANS LA CHAMBRE 2, eventTime=Wed Oct 21 15:26:02 CEST 2015, Priority=0.0}])For some reason, some alarm parameters are not stored, but i can not understand why.
Is it possible to have a more explicit message in order to find the reason why events/alarms are redirected to the buffer ?
I can provide a (large) wrapper.log file if needed.
Ignition version is 7.7.1
Database is MSSQL
Thank you.
