Alarm Journal Data Filters
Does anyone have a example of how this setting should be used?
I have the impression that I provide a sub path that filters alarms into this journal based on their source or display path. Does this work like a wildcard or is a strict 1 to 1 full source or display path.
I have a system that contains large amounts of tags for different areas. The idea is to create alarm journals and tables specific to areas in the tag browser and have alarm filter/store to this particular journal in order to reduce loading times and increase speed.
My idea was to use this setting , but I’m not 100% sure if I’m setting it correctly.
Thanks.
Yes, you can use wildcard…
https://www.docs.inductiveautomation.com/docs/8.1/platform/alarming#source-path-filter-examples
