Hello to everyone,
I have a problem with the journal component.
I use that inside three different scada projects. Same alarm journal and same components. I noticed that if I place it inside one of the three projects this will not work. The only way to work is to eliminiate the expression link inside the end date property (which is now(500))
Custom SQL directly in a binding or script?
By default, Vision clients can't run such SQL, as it is a security hole. You can enable "Legacy DB" permissions in the project properties if you absolutely must. But the correct answer is to use Named Queries (with value parameters, if necessary). Named Queries do not expose the security hole as long as you do not use QueryString parameters.
Even with "Legacy DB" permissions, I have issue to show the alarms. I had to swap the Alarm Journal Table with the Alarm Status Table.
