The alarm journal allows one to specify the table name to store events and event data. However, if the table is in a non public schema, such as mysite.events then the gateway complains about the table name having a period.
2 years later... And I stumbled across the same issue, but using SQL Server.
I have two alarm journals, each one intended to be on a different schema but on the same DB.
