Alarm Journal Printing
Looking for help on if anyone has a code snippet to print the alarm journal from what the operators select using the date range object.
Tried a few of the other ones I found on the forum but everything I find is from a while ago. Hoping there is an easier way.
Just an update.
I called into tech support to get this working and the best way to do this is through the Reporting Module (which I did not think of)
Super easy to do and use Print feature on a button.
Actually replaced the Alarm Journal graphic with this report as it is a lot nicer.
Care to share how exactly you do it?
Think that many will benefit from this…:+1:
Create the report - Select Alarm_Journal as a data source - Add Table Component to the report - I used EVENTTIME , Display Path, Ack’edBy and Current state as the 4 columns.
Created an Alarm History Screen in Vision - Put the Report Viewer Component on screen - Added a Date-Range component to screen tied the End Time and Start time to the report viewer component
Added a Button to the screen with the following on Action Performed.
report = event.source.parent.getComponent(“Report Viewer”)
report.print()
