Hello,
I’m trying to create an alarm journal profile. I left pretty much all the parameter to the default value. My datasource is a PostgreSQL database where I’m already writing to and reading from properly with my gateway scripts and my Vision client scripts. Once I’m done with the journal creation, I get the “successfully created” message.
But the link with the DB for the table creation fails. In my gateway/Status/Log, I get the following error
java.lang.Exception: Error running query: CREATE TABLE alarm_events (“id” SERIAL NOT NULL,“eventid” unspecified,“source” unspecified,“displaypath” unspecified,“priority” int,“eventtype” int,“eventflags” int,“eventtime” timestamp,PRIMARY KEY (“id”))
at com.inductiveautomation.ignition.gateway.db.schema.DBTableSchema.executeCommandSet(DBTableSchema.java:140)
at com.inductiveautomation.ignition.gateway.db.schema.DBTableSchema.createTable(DBTableSchema.java:109)
at com.inductiveautomation.ignition.gateway.db.schema.DBTableSchema.verifyAndUpdate(DBTableSchema.java:91)
at com.inductiveautomation.ignition.gateway.alarming.journal.JournalTables$EventTable.verifyTable(JournalTables.java:66)
at com.inductiveautomation.ignition.gateway.alarming.journal.AlarmJournal.verifyTables(AlarmJournal.java:161)
at com.inductiveautomation.ignition.gateway.alarming.journal.AlarmJournal.tryInit(AlarmJournal.java:141)
at com.inductiveautomation.ignition.gateway.alarming.journal.AlarmJournal.startup(AlarmJournal.java:121)
at com.inductiveautomation.ignition.gateway.alarming.journal.AlarmJournalManager.createJournal(AlarmJournalManager.java:129)
at com.inductiveautomation.ignition.gateway.alarming.journal.AlarmJournalManager$2.recordUpdated(AlarmJournalManager.java:77)
at com.inductiveautomation.ignition.gateway.alarming.journal.AlarmJournalManager$2.recordUpdated(AlarmJournalManager.java:63)
at com.inductiveautomation.ignition.gateway.localdb.PersistenceInterfaceImpl.notifyRecordUpdated(PersistenceInterfaceImpl.java:178)
at com.inductiveautomation.ignition.gateway.redundancy.RedundantPersistenceInterfaceImpl.doNotifyRecordUpdated(RedundantPersistenceInterfaceImpl.java:88)
at com.inductiveautomation.ignition.gateway.redundancy.RedundantPersistenceInterfaceImpl$RecordUpdateListener.recordUpdated(RedundantPersistenceInterfaceImpl.java:295)
at com.inductiveautomation.ignition.gateway.redundancy.RedundantPersistenceInterfaceImpl$RecordUpdateMessage.notify(RedundantPersistenceInterfaceImpl.java:346)
at com.inductiveautomation.ignition.gateway.redundancy.RedundantPersistenceInterfaceImpl$RecordUpdateListener.receiveCall(RedundantPersistenceInterfaceImpl.java:278)
at com.inductiveautomation.ignition.gateway.redundancy.QueueableMessageReceiver.receiveCall(QueueableMessageReceiver.java:47)
at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.dispatchMessage(RedundancyManagerImpl.java:852)
at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl$ExecuteTask.run(RedundancyManagerImpl.java:924)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:518)
Caused by: org.postgresql.util.PSQLException: ERROR: type “unspecified” does not exist Position: 59
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2440)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:2183)
at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:308)
at org.postgresql.jdbc.PgStatement.executeInternal(PgStatement.java:441)
at org.postgresql.jdbc.PgStatement.execute(PgStatement.java:365)
at org.postgresql.jdbc.PgStatement.executeWithFlags(PgStatement.java:307)
at org.postgresql.jdbc.PgStatement.executeCachedSql(PgStatement.java:293)
at org.postgresql.jdbc.PgStatement.executeWithFlags(PgStatement.java:270)
at org.postgresql.jdbc.PgStatement.executeUpdate(PgStatement.java:244)
at org.apache.commons.dbcp2.DelegatingStatement.executeUpdate(DelegatingStatement.java:322)
at com.inductiveautomation.ignition.gateway.datasource.DelegatingStatement.executeUpdate(DelegatingStatement.java:80)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper$SRStatement.executeUpdate(SRConnectionWrapper.java:857)
at com.inductiveautomation.ignition.gateway.db.schema.DBTableSchema.executeCommandSet(DBTableSchema.java:138)
… 24 common frames omitted
Should there be a different datatype instead of “unspecified” in the table creation query?
