I'm creating a .txt file via script that contains what is displayed in the Alarm Journal,
this would do:
journallist=system.alarm.queryJournal(parsedDateStart, parsedDateEnd, "HMI_1_alarms")
and I extracted all the values I need from the AlarmEvents, even the eventTime via BasicProperty.
The problem is that:
aEvent.getState()gives me the untranslated textaEvent.getLabel()gives me the same value as getName()
even if I can correctly view the Alarm Journal in the client:
. in the Label column I correctly see the static property Label (not the Name),
. in the Display Path property I configured the alarms to see only the name of the folder containing the alarm,
. in the Current State column I translated the four terms to shorten them and I see them translated correctly.
Do you know how could I solve this?
