Hello. I have created tags that each contains 4 alarms HIHI HI LO LOLO. I want to be able to change each setpoint on screen. The only way I can find is to create memory tag to dynamically point each alarm setpoint, which may be an issue because I have 1000 of tags that need to each have 4 alarm levels so that would be a truck load of memory tag to be created. Is there a way to directly link into a label or an data entry the SP of each alarm that exist inside a tag without having to use memory tag ? thanks
Phil
