Alarm management center
Hello,
I searched, but you can confirm that there is no alarm center in the designer, where I can organize, modify or create them without having to browse tag after tag or UDT?
If this is not the case, it would be a big added value for the tool! Because when you start having a lot of different tags, it becomes long and tedious to work on the different alarms. Especially if you want to create alarms dependent on several tags etc ...
Best regard,
Maxime Guenet
Definitely nothing exists right now. I don't really see how this would work though, especially for tags in udt definitions. You can already multi select tags and edit their alarm definitions, although you can only edit them if they all have the same alarm name (in my case this is never the case).
