1: can we have the Alarm Metrics aggregation in Provider level?
2: How can I read the Alarm Metrics structure and/or values inside in the script. since they are not tags I can’t use system.tag.read…
I believe there are alarm metrics at the root of the provider, just the "tag" doesn't appear. But if you address it, you'll get values.
yes , you are right . not sure why it is hidden though!
To save space as you don’t need to look at them all time.
not sure what could be the reason , some times if you are changing stuff alot it can be that you need to restart a folder . but not as a go to procedure.
For some reason I recall that they only update if something is subscribing to them. Just looking at them in the tag browser doesn't necessarily update them I believe.
Try binding them to a label or something and see if they update as expected.
It looks like you’re running into a bug that will be fixed in 8.3.5. Currently available in the Nightly.
IGN-15336: Alarm metrics in nested folders sometimes incorrectly reflect active alarms
Fixed an issue where Alarm Metrics in nested folders would initialize to empty and never update.
Ok, thanks
