Hi all,
I am using the Alarm Journal and Alarm Journal Table for the first time in Ignition 8 and I noticed something in the Alarm Journal Table object.
It seems to display the value of the Alarm Name property in the Label column, except when the Current State is “Active, Acknowledged”, in which case it shows the value of the Label property in the Label column.
Here is the Alarm configured in a Udt showing the Name and Label:
Here is a screenshot from the Alarm Journal table. In this case the alarm became active, was acknowledged manually in the Alarm Status object, and then was cleared:
In this case the alarm became active and then was cleared with no user acknowledgement:
Is there some configuration I am missing, or could this potentially be a bug? Thanks in advance for all replies.
