Running 7.6.2. All of my alarm tags have HTML formatting on the text in the Notes property and I’ve noticed that the notes are displayed differently in the Alarm Status Display component depending on where you look. The HTML formatting is ignored in the “Notes” tab of the Details popup, but it is not ignored if you choose to add the column to the table and also in the Details tab of the Details popup.
The main reason I want to use HTML is so that the text will wrap around when you open up the Notes tab in the Details popup. Previous to 7.6.2 you could get around this by creating a separate text box and referencing the notes of the selected alarm. I couldn’t find a way to re-create this workaround in 7.6.2. Any ideas?
