I have one table named 'task' in db . In this table, username,email,station number and task status(status=Complete or status=Not Complete) is given. Their are 20 station and each with station user will have some task that may have complete task or not complete task. I have created 20 different station in different view. In each station, two button is placed i.e Faulted or Ok.
Let say , at station 2 i press button Faulted. Now, i need to send alarm to that user only whose task is incomplete in that station based upon table record.
Now , i know that i have to use roasted type, 'calculated.' But how to start with logic? When faulted button is pressed display path as "Station 2 Faulted" will be their . How to retrieve "2" from "station 2 faulted" as we do not have option to pull up display path in calculated type
Pretty sure your question is related to one of the certification test.
Seeking help on the forum is not allowed as per the test instructions written on your document.
@Paolo.Mariani sorry for pinging you but I think you are related to this topic ?
This is too close to a test question, the topic was closed, do not ask for help related to Certification Tests on the forums.
Thank you Samuel for notifying us.
