Hello, I have some problems in the new version to configure alarm notification profiles correctly. I am using the following configuration:
Hostname: smtp.namecompany.com
Port: 25
Enable SSL: false
Username: <nameuser>
Password: <password>
This configuration is the same as in version 7.5 where emails are sent correctly. However, the new version displays the following exception:
javax.mail.SendFailedException: Invalid Addresses;
nested exception is:
com.sun.mail.smtp.SMTPAddressFailedException: 553 We do not accept mail from IP addresses without reverse DNS.
Caused by: com.sun.mail.smtp.SMTPAddressFailedException: 553 We do not accept mail from IP addresses without reverse DNS.
On the other hand, if I change the port to 465 (enable SSL = true) then emails are sent without problems. Why in the previous version works perfectly and now appears this exception?
