Hi
I use a Sierra Wireless raven RV50 to send SMS messages when alarms are raised in Ignition (v7.9). I currently use the following message format:
{displayPathOrSource} ALARM! {notes}. {eventTime|hh:mm:ss}
If the displayPath field is empty, a user could receive the following SMS:
WATERCON/Alarms/Alarm 014/Alarm 014/ ALARM! Water level - A110LT001 - High level 11:29:54.
WATERCON is the machine name. I would like the text message to appear as follows:
WATERCON ALARM! Water level - A110LT001 - High level 11:29:54.
Is there a way to strip the path from “Source” variable so that I can return just the machine name and the rest of the text as shown above? The alternative is to export all my alarms for each machine, add the “displayPath” line and then re-import.
Thanks for looking!
