Alarm pipeline notification block edit error
I am having trouble with the notification block - I cannot edit it in my pipelines anymore.
I had to update just the voice and alarm pipelines to fix another issue but i’m not sure if that is the root of my problem - the problem started after the update.
when I click on the notification block in the designer, I receive this error:
ExecutionException: java.lang.NoClassDefFoundError: com/inductiveautomation/ignition/client/util/gui/DebouncedCatchAllListener
	caused by NoClassDefFoundError: com/inductiveautomation/ignition/client/util/gui/DebouncedCatchAllListener
Ignition v7.9.3 (b2017060210)
Java: Oracle Corporation 1.8.0_151
My modals are as follows:
Alarm Notification 4.9.9 (b2018081614) Activated RUNNING
Modbus Driver 5.9.3 (b2017060210) Activated RUNNING
OPC-UA 4.9.3 (b2017060210) Activated RUNNING
Reporting 4.9.3 (b2017060210) Activated RUNNING
SMS Notification 4.9.6 (b2018012914) Activated RUNNING
SQL Bridge 8.9.3 (b2017060210) Activated RUNNING
Symbol Factory 5.9.3 (b2017060217) Activated LOADED
TTS Voice - en_us_katherine 3.8.2 (b0) Activated RUNNING
Tag Historian 2.9.3 (b2017060210) Activated RUNNING
UDP and TCP Drivers 4.9.3 (b2017060217) Activated RUNNING
User Manual 4.9.3 (b2017060217) Free RUNNING
Vision 9.9.3 (b2017060217) Activated RUNNING
Voice Notification 4.9.9 (b2018081622)
PS. It is just the notification block that is causing the error.
thanks for reading
That's definitely the source of the problem. The class that's missing was added in 7.9.4. I'm not sure why you upgraded just those two modules, but you'll have to upgrade the platform/all modules to get the pipelines to work properly.
Thanks, will do - I figured as much. The upgrade was a quick fix i didn’t have time to upgrade the rest.
