Alarm Pipeline Notification Block Test Mode Function
What is the purpose of the "test mode" function in the alarm pipeline notification blocks? I personally see no difference whether or not it is turned on.
That's what I had thought, but I current have this pipeline set to test mode enabled, yet I still received an email.
You've saved your changes to the pipeline? No project inheritance at play?
You should only be seeing something in the logs from alarm.Notification.EmailNotificationProfile at INFO level, no actual email sent.
"THIS IS A TEST" doesn't match the configuration of the notification block in that screenshot.
Do you have any other pipelines?
I believe I hadn't saved my changes to the gateway, apologies for the easy to catch mistake. It seems to be functioning as expected.
