Hi guys,
I’m having a problem setting up the alarming system. I want to get emails when tags’ values are out of range, I have create a very simple pipeline for this (Start ->Notification Block), I tested it using the “Test pipeline and notification…” in the gateway webpage and I got the test email. I set few tags’ alarms associated with the created pipeline and then I hardcoded the tags’ values in order to test the alarms but I only got 1 notification email for the first tag I configured.
Looking at the gateway’s logs I found the following message:
BlockEvaluationContext The alarm event ‘c8c5c9d5-4642-4849-a036-cecaaec3b3b5’ will be dropped from the pipeline, due to pipeline dropout conditions, cancellation, pipeline conditions, or loop detection.
I’m seeing that message for every tag alarm I configure except the first one, I understand in this case the alert condition was reached but the pipeline is not sending the notification for some reason.
Could you help me with this please?
This is a log for another alert, you will see all the logs’ entry for this particular alert.
19:43:52 BlockEvaluationContext The alarm event ‘7c010697-fbaf-412e-8bfb-56d068c64d8e’ will be dropped from the pipeline, due to pipeline dropout conditions, cancellation, pipeline conditions, or loop detection.
(D) 19:43:52 Manager Processing alarm transition: prov:default:/tag:XXX->Active, id: 7c010697-fbaf-412e-8bfb-56d068c64d8e
(D) 19:43:52 Manager Processing alarm transition: prov:default:/tag:XXX->Finished, id: 8fb7915f-c352-41ae-b585-3ade06a17b2c
(D) 19:43:52 Execution (prov:default:/tag:LAChx4/NivelAltoPileta:/alm:XXX : 1577523475) Finished event ‘8fb7915f-c352-41ae-b585-3ade06a17b2c’. Remaining live events: 1
(D) 19:43:52 Execution (prov:default:/tag:LAChx4/NivelAltoPileta:/alm:XXX : 1577523475) Registered live event ‘7c010697-fbaf-412e-8bfb-56d068c64d8e’, state: Active, Unacknowledged. Outstanding events: 2
(D) 19:43:52 Execution (prov:default:/tag:LAChx4/NivelAltoPileta:/alm:XXX) The transition to Active will be marked as an ‘initial event’.
(D) 19:43:24 StateManager Registering alarm: prov:default:/tag:XXX
