Using Ignition 7.6.3rc1
Was experimenting with the pipelines and ran into a couple of snags or features.
I exported a pipeline to save it with no problem but when I deleted this pipeline and tried to bring it back in via the import function it didn’t work. Import doesn’t seem to do anything but when you go to the tag alarm properties and click on the pipeline to use a bunch of duplicates show up after you use the import function even though nothing shows up in the alarm pipelines design area.
Also what does the folder function in the alarm pipelines do? I set up two different folders and made a loop pipeline under each folder. It allows you to do this but in the alarm properties of a tag there is no way to select a folder to pick which loop to use.
Thanks,
