Alarm & Pipeline Trigger for Any Tag Value Change
Hello, I’m very new to Ignition and have been trying to use a notification pipeline with a tag alarm.
As the “any change” alarm mode instantly clears the alarm, I do not know how to configure an alarm so that once the alarm is active it can continue to trigger the notification pipeline every time the tag value changes.
For context, the tag value is a 32 bit word used by a script to create status messages and send them to Slack. I’ve been trying not to use a Tag Event Script or Gateway Event Script as I will need to apply this message script to many tags via script.
This accepts a list of tags to monitor.
Is there a way to add paths to the list through script or any other non-manual means? I haven’t been able to find anything on that
No, unfortunately.
