Hello all!
Until recently I’ve configured “Active Pipeline” in my tags with a reference to a UDT parameter for my tags. I created a parameter called Database with the string value MU01, and could refer to the active pipeline MU01/Pri1 by using the expression {Database}/Pri1.
In later version… somewhere between 8.1.3 and latest version of Ignition, that expression stopped working. It seems like a referance to a UDT parameter no longer works with my previous expression as {Database} now counts as null. The UDT parameter still contains the stringed value of MU01. I created a memory tag with the same stringed value, and put that into my expression, still with the old syntax, still didn’t work> {StringTag}/Pri1
Then it occured to me, you may have changed the tag property expressions to work in the same manner as expressions in general. Changing the expression to {StringTag}+“/Pri1” seemed to do the trick, and tbh it all makes sense.
This will however cause an issue whenever we want to upgrade our customer projects.
The question is, was this change intentional? Is it not longer possible to refer to UDT parameters in the Alarm Properties?
