Hello
. I need to make an alarm report, in which the frequency of each type of alarm should appear. for example:
critical alarms >> n times
medium alarms >> n times
etc
Does anyone know how it can be done? or have an example of alarm reporting. Thanks a lot.
Use sample project available at https://inductiveautomation.com/exchange/95/overview . On ignition exchange use sample project of Alarm Analysis
Thank you.
I was looking at it, I thought about saving all that information in a table in the database, to be able to access it from the reporting module.
Hi…It is already there. This application is fetching data from SQL DB. Whenever you apply filter from the screen, it generate queries and show you data on the screen. Just create one DB and read the help when you restore exchange backup.
thanks you , i will read more about it.
