We are having trouble getting the alarm status table in vision to work, any assistance is greatly appreciated:
Ignition 8.1.30 running on Windows Server
Alarm Status Table has error on alarmEvents = Error_IO
More information...
system.alarm.queryStatus() throws the following error:
Java Traceback:
File "<input>", line 1, in <module>
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:360)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:334)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:287)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:967)
at com.inductiveautomation.ignition.client.script.ClientAlarmUtilities.queryStatusImpl(ClientAlarmUtilities.java:41)
at com.inductiveautomation.ignition.common.script.builtin.AbstractAlarmUtilities.queryStatus(AbstractAlarmUtilities.java:81)
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Error executing gateway function.
at org.python.core.Py.JavaError(Py.java:547)
at com.inductiveautomation.ignition.common.script.builtin.AbstractAlarmUtilities.queryStatus(AbstractAlarmUtilities.java:83)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:552)
at org.python.core.PyObject.__call__(PyObject.java:400)
at org.python.pycode._pyx28.f$0(<input>:1)
at org.python.pycode._pyx28.call_function(<input>)
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.Py.runCode(Py.java:1687)
at org.python.core.Py.exec(Py.java:1731)
at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:277)
at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:130)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:626)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:614)
at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Error executing gateway function.
... 23 more
Caused by: java.lang.NullPointerException
at com.inductiveautomation.ignition.client.gateway_interface.ResponseParser.startElement(ResponseParser.java:361)
at java.xml/com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:498)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:292)
... 27 more
We recently just had this error but was able to fix it by restarting the gateway. Would also like to know as well what's the cause of this?
