Alarm status table - header/data text alignment
as per the attached screenshot, I’m running in an aesthetic issue regarding text alignment between alarm status table header and related data.
Header is centered and data are left-aligned. I did not found any away to managed that. I also tried with translator manager and html formatting. It is simply ignored.
Is there a way, at least, to have all (header and data) aligned in the same way? Best would be being able to choose but reasonable to have all coherent (all left aligned).
Thanks in advance for your help.
Elio Cutino
6667616b-7682-4e95-996a-0bb20f9c7df2
I have the same problem. Did you find a solution to this?
