Hey guys,
If I try and display an alarm status table on a pop up window that is docked without a header on it I get the following error:
[code]com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Error invoking [AlarmStatusTable]com.inductiveautomation.factorypmi.application.components.AlarmStatusTable[Alarm Status,0,0,1024x100,invalid,layout=java.awt.BorderLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=16777217,maximumSize=,minimumSize=,preferredSize=java.awt.Dimension[width=500,height=400]].setShowTableHeader(false)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.handlers.ObjectDeserializationHandler.endSubElement(ObjectDeserializationHandler.java:81)
at com.inductiveautomation.factorypmi.application.xmlserialization.ComponentDeserializationHandler.endSubElement(ComponentDeserializationHandler.java:93)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$ParseContext.onElementEnd(XMLDeserializer.java:663)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:165)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:157)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.parse(BinaryParser.java:51)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserializeBinary(XMLDeserializer.java:313)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserialize(XMLDeserializer.java:233)
at com.inductiveautomation.factorypmi.application.model.WindowCache._deserializeWindow(WindowCache.java:277)
at com.inductiveautomation.factorypmi.application.model.WindowCache._loadWindow(WindowCache.java:216)
at com.inductiveautomation.factorypmi.application.model.WindowCache.openWindow(WindowCache.java:435)
at com.inductiveautomation.factorypmi.application.FPMIApp$RuntimeWindowOpener.openWindow(FPMIApp.java:1553)
at com.inductiveautomation.factorypmi.application.FPMIApp.openWindow(FPMIApp.java:922)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities$5.run(NavUtilities.java:417)
at com.inductiveautomation.factorypmi.application.script.builtin.WindowUtilities.doGUIAction(WindowUtilities.java:607)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.openWindowImpl(NavUtilities.java:352)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.openWindow(NavUtilities.java:347)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:186)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.call(ScriptManager.java:459)
at org.python.core.PyObject.call(PyObject.java:404)
at org.python.core.PyObject.call(PyObject.java:408)
at org.python.pycode._pyx111.f$0(event:mouseReleased:5)
at org.python.pycode._pyx111.call_function(event:mouseReleased)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.Py.runCode(Py.java:1275)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:552)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:155)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:266)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:55)
at $Proxy16.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$000(Unknown Source)
at java.awt.EventQueue$1.run(Unknown Source)
at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$2.run(Unknown Source)
Caused by: java.lang.reflect.InvocationTargetException
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.handlers.ObjectDeserializationHandler.endSubElement(ObjectDeserializationHandler.java:68)
… 74 more
Caused by: java.lang.NullPointerException
at com.inductiveautomation.factorypmi.application.components.AlarmStatusTable.setShowTableHeader(AlarmStatusTable.java:635)
… 79 more
Ignition v7.6.0 (b1875)
Java: Sun Microsystems Inc. 1.6.0_24
[/code]
