How can I set up an alarm summary object. I have the query down, just can’t seem to get the data to display.
I’ve run into this and it was because I didn’t have database traffic turned on. To the right of the new screen icon at the top of the screen are three icons that look like databases. Use the far right one of these three to turn traffic on in the designer.
But, if that doesn’t do it, would you supply more detailed information I.e., the actual query used, some detail about the table you are using, the steps you went through and the exact things noted.
But hopefully, the first thing takes care of it.
Thanks. I was trying to return the information to a text box. As soon as I switched it to a table, everything came through nicely. Thanks again.
