Trying to configure Ignition 7.6.5-RC4 to send test alarm. On the SMTP server see no attempted connection from Ignition server. As far as I can tell (not really knowing java) seems something is stopping Ignition from even attempting connection to the SMTP.
INFO | jvm 1 | 2014/03/14 13:40:54 | DEBUG [NotificationBlock ] [13:40:54,430]: Sending AlarmEvent ‘{Source: ‘sys:configpage:/alm:**TEST’, Display Path: ‘TestPage/TEST_ALARM’, UUID: ‘d40bb011-0816-49b5-b46c-aefaa3fec47f’, Current State: ‘Active, Unacknowledged’, Priority: ‘Diagnostic’, Active Data: {eventTime=Fri Mar 14 13:40:24 CDT 2014}, Clear Data: null, Ack Data: null, Runtime Data: {pipelineName=test_pipeline, pipelineTransitionCount=2, pipelineVersion=3}}’ for notification.
INFO | jvm 1 | 2014/03/14 13:40:54 | WARN [NotificationBlock ] [13:40:54,436]: Uncaught Throwable during notification.
INFO | jvm 1 | 2014/03/14 13:40:54 | java.lang.NullPointerException
INFO | jvm 1 | 2014/03/14 13:40:54 | at com.inductiveautomation.ignition.alarming.pipelines.blocks.NotificationBlock$NotificationContextImpl.profiles(NotificationBlock.java:362)
INFO | jvm 1 | 2014/03/14 13:40:54 | at com.inductiveautomation.ignition.alarming.pipelines.blocks.NotificationBlock$NotificationContextImpl.profile(NotificationBlock.java:336)
INFO | jvm 1 | 2014/03/14 13:40:54 | at com.inductiveautomation.ignition.alarming.pipelines.blocks.NotificationBlock$NotificationContextImpl.run(NotificationBlock.java:293)
INFO | jvm 1 | 2014/03/14 13:40:54 | at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:526)
INFO | jvm 1 | 2014/03/14 13:40:54 | at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
INFO | jvm 1 | 2014/03/14 13:40:54 | at java.util.concurrent.FutureTask.run(FutureTask.java:262)
INFO | jvm 1 | 2014/03/14 13:40:54 | at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:178)
INFO | jvm 1 | 2014/03/14 13:40:54 | at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:292)
INFO | jvm 1 | 2014/03/14 13:40:54 | at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
INFO | jvm 1 | 2014/03/14 13:40:54 | at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
INFO | jvm 1 | 2014/03/14 13:40:54 | at java.lang.Thread.run(Thread.java:744)
INFO | jvm 1 | 2014/03/14 13:40:54 | DEBUG [NotificationBlock ] [13:40:54,436]: Scheduled notification to next user for +0ms
INFO | jvm 1 | 2014/03/14 13:40:54 | WARN [NotificationBlock ] [13:40:54,437]: Uncaught Throwable during notification.
DEBUG | wrapperp | 2014/03/14 13:40:57 | send a packet PING : ping
