Hi everybody,
I need help about the alarm configuration parameter.
I have an UDT tag and in the alarming try to set the ENABLED parameter to an expression tag.
I´d like when the two boolean tags are true the alarm will be ENABLED by this parameter but it doesn´t work right. When i put the expression the alarm is always enable.
Thank you very much.
Kind regards.
Mr. Eduardo Ojalvo
