I want to use the AlarmScreen from the ExampleProject and it appeared fine on my laptop (note I have not altered it from the ExProj) but when I imported my project to my server it started generating errors. I get an Error executing expression binding on AlarmScreen.Root Container.Alarms.AlarmTable.data, how do I resolve this error?
Here are the details from the first of many:
java.lang.Exception: Error executing expression binding on
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.runExpression(ExpressionPropertyAdapter.java:56)
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.startup(ExpressionPropertyAdapter.java:75)
at com.inductiveautomation.factorypmi.application.FPMIWindow.startupAdapters(FPMIWindow.java:264)
at com.inductiveautomation.factorypmi.application.FPMIApp.openWindow(FPMIApp.java:929)
at com.inductiveautomation.factorypmi.application.FPMIApp.openWindow(FPMIApp.java:872)
at com.inductiveautomation.factorypmi.designer.model.ObjectHolder.openWindow(ObjectHolder.java:3710)
at com.inductiveautomation.factorypmi.designer.model.navtree.WindowNode.onDoubleClick(WindowNode.java:439)
at com.inductiveautomation.ignition.designer.navtree.NavTreePanel$MouseListener$1.run(NavTreePanel.java:513)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
Caused by: com.inductiveautomation.ignition.common.expressions.ExpressionException: Error executing script for runScript() expression:app.alert.alertHistory(‘Alert’, ‘2010-03-17 17:06:28’, ‘2010-03-18 17:06:28’, 1)
at com.inductiveautomation.ignition.common.expressions.functions.ScriptFunction.execute(ScriptFunction.java:57)
at com.inductiveautomation.ignition.common.expressions.FunctionExpression.execute(FunctionExpression.java:69)
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.runExpression(ExpressionPropertyAdapter.java:50)
… 15 more
Caused by: Traceback (innermost last):
File “expression:runScript”, line 1, in ?
File “module:alert”, line 7, in alertHistory
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Gateway Error 500: Alert storage profile “Alert” does not exist.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:238)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:213)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:203)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:601)
at com.inductiveautomation.factorypmi.application.script.builtin.ClientAlertUtilities.queryAlertHistoryImpl(ClientAlertUtilities.java:42)
at com.inductiveautomation.ignition.common.script.builtin.AbstractAlertUtilities.queryAlertHistory(AbstractAlertUtilities.java:75)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:310)
at org.python.pycode._pyx1.alertHistory$2(<module:alert>:7)
at org.python.pycode._pyx1.call_function(<module:alert>)
at org.python.core.PyTableCode.call(PyTableCode.java)
at org.python.core.PyFunction.__call__(PyFunction.java)
at org.python.core.PyObject.__call__(PyObject.java)
at org.python.core.PyObject.invoke(PyObject.java)
at org.python.pycode._pyx5.f$0(<expression:runScript>:1)
at org.python.pycode._pyx5.call_function(<expression:runScript>)
at org.python.core.PyCode.call(PyCode.java)
at org.python.core.Py.runCode(Py.java)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:391)
at com.inductiveautomation.ignition.common.expressions.functions.ScriptFunction.execute(ScriptFunction.java:54)
Caused by: java.lang.IllegalArgumentException: Alert storage profile “Alert” does not exist.
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.Alert.queryHistory(Alert.java:40)
at sun.reflect.GeneratedMethodAccessor305.invoke(null)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(null)
at java.lang.reflect.Method.invoke(null)
at com.inductiveautomation.ignition.gateway.servlets.gateway.AbstractGatewayFunction.invoke(AbstractGatewayFunction.java:160)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:379)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:85)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(null)
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Gateway Error 500: Alert storage profile “Alert” does not exist.
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:394)
... 17 more
at org.python.core.Py.JavaError(Py.java)
at com.inductiveautomation.ignition.common.script.builtin.AbstractAlertUtilities.queryAlertHistory(AbstractAlertUtilities.java:83)
... 18 more
Ignition v7.1.6 (b5739)
Java: Sun Microsystems Inc. 1.6.0_22
