Is it possible in any way to change the Name of an alert in the Alarm Configuration dynamically? Such as an expression or alert property references? Or might it be possible to change it from a python script that writes to the property? If not is there any way to display an alert custom property in the Alarm Status Table (i.e. - I create a property called Alert Display Name that will then show up as a column in the Alarm Status Table)? The reason I am asking is that I would like to set up a screen that would allow our facility manager to change the alert Name (or a Display Name) on his own without having to ask me to do it for him. I cannot use the Display path because we are already using that as a filter for the Alarm Status Table. Appreciate any help.
Thanks,
-Will
