Hi, I have a South docked window which contains an Alert Status Table. The Window grows to fill out the monitor but the Alert Status Table does not. Is there a setting, other than scripting, that will tell the Table to grow with the window?
Use component layouts on the alarm table.
Probably the anchored on left, right and bottom is what you want, but you have to set, update the client and try different ones until you get wath you want.
Regards,
