Is it possible to add option to display OPCItemPath field from the tag on the alert summary table? I looked into the alert console, but it is only logging System/Path field, which is SQLTags.default in my case.
Want to show the OPC path of the alarmed tags on the table
Right now you can show the Item Path and Path. The Item Path is the path to the SQLTag. The Path will be the Item Path if the Display Path is not set otherwise the Display Path. The Display Path is a free form string that you can set to the OPC Item Path or anything else. It is not built in to show the OPC Item Path right now. We will look into this request more.
