I have an equipment scheduler with label taken from the database as arranged. I would like to use an static alias for the label (of items - shown to be on the left ) in equipment scheduler, just for being more informative to the operator. Any suggestion?
If truly static, you could append it to the column in your sql query (SELECT 'Prefix-' + [sqlColumn] FROM [table]). Or, use a script transform in the binding to iterate through the json object and modify/add what you wish.
Thanks for your replies. It is clear.
