Align Keyboard shortcuts
Working in designer, and find myself using the align buttons pretty often. Is there a keyboard shortcut for “Align (side) edge of objects”, or is there a way to setup custom key shortcuts?
https://docs.inductiveautomation.com/display/DOC81/Keyboard+Shortcuts#KeyboardShortcuts-UsingKeyboardShortcutsintheDesigner
doesnt look like it
idk if there is an other way, but to add a keybinding you probably will have to dig into the javadocs for it. And probably will require you to make a module, which is quite the work xd
https://files.inductiveautomation.com/sdk/javadoc/ignition81/8.1.15/com/inductiveautomation/ignition/designer/gui/DesignerToolbar.html
Ignition is great, but shortcut keys are such a basic feature every development tool should have. It's a pity it lacks that.
