I am facing an issue of alignment in Ignition Perspective. There is a coordinate container in a flex container where I am trying to view this in a Tablet and having issue in viewing this correctly.
Hope I am doing this right or is there a better way.
The flex container is probably set to preserve the original view size of your coordinate container. If your coordinate container is in relative mode, and you’ve unchecked the preserve original view size on the flex container, it should scale down for you.
Enabling the coordinate container in relative mode did help but the gauge component shrunk to an extent it’s not visually accurate.
Is there a way in which coordinate container resize and the gauge component can be dynamic.
