I'm building a report with a startTime and endTime and it works when I pull the dates from existing shift tags in ignition.
However, I'm trying to pull the dates from report parameter list and mssql query freezes up. The query handles fine if I pull from shift tags, so I believe it has to do with date format in expressions vs date format in python/ignition. I can't find out how to correct and hoping someone can walk through data types. ![]()
I'm trying to pass in flexible dates through the parameters rather than pull from tags.
Heres' the two parameters in the report setup:
Here's the CurrentShiftTimeStart tag that I pull that works in the query. End is setup the same way:
Heres' the named query call:
MSSQL table that datetime format is. Not sure if this helps:
EDIT: When I say hung, I mean the connection to DB in gateway stays open much longer than it should (eventually times out) then my designer pops up this error and icon:
java.util.concurrent.ExecutionException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Read timed out
at java.base/java.util.concurrent.FutureTask.report(Unknown Source)
at java.base/java.util.concurrent.FutureTask.get(Unknown Source)
at java.desktop/javax.swing.SwingWorker.get(Unknown Source)
at com.inductiveautomation.reporting.designer.workspace.design.SampleData$SampleDataLoader.done(SampleData.java:145)
at java.desktop/javax.swing.SwingWorker$5.run(Unknown Source)
at java.desktop/javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.run(Unknown Source)
at java.desktop/sun.swing.AccumulativeRunnable.run(Unknown Source)
at java.desktop/javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.actionPerformed(Unknown Source)
at java.desktop/javax.swing.Timer.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.Timer$DoPostEvent.run(Unknown Source)
at com.inductiveautomation.snap.swing.RibsEventQueue.dispatchEvent(RibsEventQueue.java:99)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Read timed out
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:351)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:543)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:283)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:278)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.moduleInvokeSafe(GatewayInterface.java:908)
at com.inductiveautomation.ignition.client.gateway_interface.ModuleRPCFactory$DynamicRPCHandler.invoke(ModuleRPCFactory.java:53)
at com.sun.proxy.$Proxy63.getReportData(Unknown Source)
at com.inductiveautomation.reporting.designer.workspace.design.SampleData$SampleDataLoader.doInBackground(SampleData.java:135)
at com.inductiveautomation.reporting.designer.workspace.design.SampleData$SampleDataLoader.doInBackground(SampleData.java:112)
at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: java.net.SocketTimeoutException: Read timed out
at java.base/java.net.SocketInputStream.socketRead0(Native Method)
at java.base/java.net.SocketInputStream.socketRead(Unknown Source)
at java.base/java.net.SocketInputStream.read(Unknown Source)
at java.base/java.io.BufferedInputStream.fill(Unknown Source)
at java.base/java.io.BufferedInputStream.read1(Unknown Source)
at java.base/java.io.BufferedInputStream.read(Unknown Source)
at java.base/sun.net.www.http.HttpClient.parseHTTPHeader(Unknown Source)
at java.base/sun.net.www.http.HttpClient.parseHTTP(Unknown Source)
at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream0(Unknown Source)
at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at java.base/java.net.HttpURLConnection.getResponseCode(Unknown Source)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:437)
... 13 more
Ignition v8.1.17 (b2022051210)
Java: Azul Systems, Inc. 11.0.15
Thanks!!
Earl
