All of my Bacnet devices changed from initialized to uninitalized
We had an ignition edge server that we used for development. This server had 60+ BACnet devices that were initialized and working properly. Recently we made a gateway backup and migrated it to a panel HMI. On this new HMI everything is working properly except the BACnet devices.
We can ping them no problem but now all of the devices say uninitialized and we are unsure how or why this happened or how to initialize them again.
We went back to the original server and all the devices are initialized there so it doesn't seem to be an issue with the devices or network.
It seems to be an issue with the HMI itself, but given that it was restored from a gateway backup and the ip address is configured properly we are not sure what specifically the issue is.
Any help is appreciated, thank you.
Check that the BACnet "Local Device" is configured for a bind address of e.g. 0.0.0.0 and not whatever IP address belonged to the other Gateway.
found the issue, the firewall was in the way
