Hello, I am very new to Ignition and would like to know if ignition can communicate directly to an Allen-Bradley ArmorBlock without a PLC. I can’t find any reference to this so I assume that it is not possible without a PLC to be able to grab the tags from.
Maybe with @pturmel’s 3rd party EtherNet/IP module, but not with any of Ignition’s built-in modules.
You would need to bring the I/O into a PLC and access the tags via our driver for that PLC.
Thanks for the quick reply, I did see the EtherNet/IP module, I will look a little further into it.
Yes, my module’s scanner mode (premium) should have no trouble.
