Allen Bradley Drivers
Is there going to be a Driver available for the Allen Bradley Micro800 series Plc?
These Plc’s are becoming very popular in the small machine builders and Oilfield automation.
I know you can connect with Modbus Tcp but a actual driver would make it so much more simpler.
We can revisit the idea after Ignition 8 is released.
Last time I checked the device still doesn’t support browsing or accessing anything but atomic tags in the global namespace.
Thank you for the update.
Let me just add this bit of information.
I use the Maple System Hmi for almost all of my projects, I don’t know how they accomplish this, but this is how their driver works.
If I copy and paste - then I can only use the “GLOBAL” variables from the Micro800 series PLC.
HOWEVER if I “IMPORT” the variables from an exported list then I can use Both “GLOBAL” and “LOCAL” variables in the HMI.
Thanks Again
