Is there a built in function in Ignition that allows a client to place a tag into a particular group, so that calculations/actions can be made based off of that meaningful grouping.
Example :
In the Oilfield there is a concept called Lost and Unacounted for Gas.
It helps to find leaks. The relationships are that there are a certain amount of wells to a booster, certain amount of boosters to a compressor, and a certain amount of compressors to a salespoint.
The basic theory is that all the wells that are upstream of a certain booster’s total volume summed should be within 3-4% of that booster’s total volume.
Because which wells go to which boosters etc. changes all the time, a wizard would need to be made to allow a client to indicate those relationships and have it populate “gateway” wide.
to sum up what I’m asking for : Is there an easy way for clients to determine relationships (such as which tags go into a transaction group?)
