Allowing Unsigned Modules to Run in 7.9
I recently upgraded to 7.9 and I want to run unsigned modules for development purposes. I’ve followed the instructions in this thread about adding -Dignition.allowunsignedmodules=true to my ignition.conf file, but I still get the ‘This module is not signed and will not load because you are not in developer mode.’ error when I try to install the module.
Has something changed since that thread was created? Is there a particular place in the ignition.conf file that line needs to go?
Exactly where did you add the allowunsignedmodules entry? I added the entry to my ignition.conf as shown below, and it worked as expected:
wrapper.java.additional.1=-XX:+UseConcMarkSweepGC
wrapper.java.additional.2=-XX:+CMSClassUnloadingEnabled
wrapper.java.additional.3=-Ddata.dir=data
wrapper.java.additional.4=-Dorg.apache.catalina.loader.WebappClassLoader.ENABLE_CLEAR_REFERENCES=false
wrapper.java.additional.5=-Xdebug
wrapper.java.additional.6=-Xrunjdwp:transport=dt_socket,server=y,suspend=n,address=8001
wrapper.java.additional.7=-Dignition.allowunsignedmodules=true
That does it. I was just dropping the ‘-Dignition.allowunsignedmodules=true’ line in the file, without the ‘wrapper.java.additional.7’ prefix.
Thanks for the help!
