Allows only Numeric Values
Dear Carl.Gould,
How to allows to Enter only Integer Values ?.
Regards
Pradip Waghmare
What component are you using?
For the Numeric Text Field, for example, you can set the Number Type to “Integer”, Bind to the Value (Integer) property as necessary, and set the Decimal Format string to change the number display formatting.
Questions like this are pretty tough to answer. You’ve got to give us some context - FactoryPMI is a pretty big application - what/where/how/why?
Also - this belongs in the design help forum not the problems forum.
